I have a divx file that is 740 mb, can i get this file to fit on a 80 min cd?
An 80 minute CD-R can fit up to 800MB without overburning. Check out this guide to learn more about the data capacity's of CD-R's:
https://www.videohelp.com/forum/userguides/135642.php
Hope That Helps!!!:P
No, not without overburning and 40MB is a lot of overburning. You can try a 90min or 99min CDR.
DivX files are burnt as normal Mode1 data. In mode1 an 80min CDR holds 700MB of data. x(S)VCDs are burnt in mode2. In mode2 an 80min CDR holds 800MB of data. -
Originally Posted by Vejita-sama
VOB File and CD overburn Query
By scott274 in forum Newbie / General discussionsReplies: 8Last Post: 17th Nov 2009, 01:54 -
Overburn Writing
By g_pentium in forum AudioReplies: 6Last Post: 7th Aug 2007, 09:08
