Hope this one is another stupid oversight on my part.
I capture all my video from digital cable TV and usualy have no problem assempling the correct filters required to correctly convert clips. But, there seems to be 1 or 2 channels that deliver their signal in a way that very much test my abilities!!!
I have placed 2 sample clips (about 600kbs each) at the following webpage http://mywebpages.comcast.net/mig317/help.htm. I would like to encode these to 480x360 (which is my normal final resolution) or larger. If you could enlighten me with a successful filter combination I would be very greatful.
My ntsc clips are captured via the compostite inputs of my WinTV-FM. I capture @ 720x480 using the Huffyuv_2.1.1 codec.
*Note - The clips at the link above are RAW except for the fact that they have been re-encoded using DivX_4.12 only to reduce filesize.
Best Regards,
Golem
It might help if you actually posted a problem. Interesting reading, but we can't give you an answer if you don't ask a question...
These appear to be true interlaced material. You should just encode them as source: interlaced, output: inerlaced.Impossible to see the future is. The Dark Side clouds everything... -
Well, guess I should have said "interlace problem".
I have tried using four different deinterlacing filters and a telecine filter, alone, and in different combinations. For some reason I can not seem to find the right settings for these clips. Playback on a PC media player is intended.
Regards! -
That's a bit better. If you have to deinterlace a true interlaced source for PC display, you can try frame doubling, or you can simply reduce the vertical resolution by two. There is a built in filter in virtualdub that will do this.
There are alot of good de-interlacing filters for VirtualDub. Search the forum for 'dgraft' to get you started.
You can also look here: http://sauron.mordor.net/dgraft/Impossible to see the future is. The Dark Side clouds everything... -
My favorite resolution!! Not anymore, here's why. Not a multiple of 16 try 512x384 instead.
I use (in order) Deinterlace/Smart Resize(bicubic)/2d Noise Reduction. Sometime I use noise reduction and/or temporeal softener depending on the channel properties.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Followup. Certain TV channels will jsut suck. Ones that fall on a multiple of you PCI or Memory bus frequency. ALos, no 2 TV channels have there video settings quite the same. I spent 6 years as a Cable TV engineer, I have some experience here. Also, certain scrambled channels can give capture cards fits, due to the sync supression.
Figuring out if different fps rates are actual reason for different times
By cinesimon in forum Newbie / General discussionsReplies: 5Last Post: 29th Aug 2011, 22:53 -
Photo Frame, and figuring out best dimensions
By snafubaby in forum Portable VideoReplies: 2Last Post: 21st Dec 2008, 03:37 -
[Solved] Question about MPlayer filters in FFDShow and Mencoder filters
By BlooderButcher in forum Video ConversionReplies: 4Last Post: 24th Nov 2008, 11:32 -
problem with ogg filters
By mehdi0016 in forum Newbie / General discussionsReplies: 2Last Post: 8th Jan 2008, 09:46 -
Figuring out why this AVI file crashes MPC & AVIcodec
By DRP in forum Software PlayingReplies: 14Last Post: 11th Nov 2007, 20:19
