I ripped The Barbershop and frameserved it w/ DVD2AVI and even encode it w/ TMPGEnc plus, burn it as SVCD, and now I found out that the video and sound are out of syn. I happen to delete all of the vob files as well. Is there any way that I can edit the video file, which I will use VCDEasy to rip and make the sound and video goes togerther w/ any syn problem at all? Please help me. Thankyou very much.
If your files are already split, then your problem would probably take more work to fix than it would to simply rent it for $3.00, and rip it again.
You can use various WAV editors, to force the length of the WAV to match your MPEG. Use TMPGenc Demultipex to extract your audio back out.
Again, I'd suggest you just rent the DVD again...Impossible to see the future is. The Dark Side clouds everything...
Video/sound out of sync and lagging on pc
By keaze in forum Newbie / General discussionsReplies: 3Last Post: 15th Mar 2012, 22:09 -
Sound out of sync in ulead video studio..
By iames85 in forum AudioReplies: 5Last Post: 24th Apr 2011, 04:10 -
DVD Video/Sound out of sync!
By bprobinson in forum Authoring (DVD)Replies: 0Last Post: 23rd Feb 2010, 15:51 -
DIVX sound and video not in sync
By DarkPhoenix77 in forum MacReplies: 2Last Post: 27th Feb 2009, 11:48 -
Video and Sound are out of sync help!
By Rhoads in forum Authoring (DVD)Replies: 1Last Post: 14th May 2007, 20:11
