  1. Hello everybody!
    I started capturing with Huffy codec with a BT8x8 card, BTWinCap drivers and Virtual Dub. I captured the 8th episode of Earth 2.
    Then I encoded the captured AVI with TMPGEnc to have a Half-DVD mpeg2 file.
    And what happens is that on fast moving scene (for example, when Devon stands up quickly and run towards her son) there are ghosty shadows...
    I cannot understand if it depends on the encoding options or because of the Huffy codec. Unfortunately I cannot play the AVI file with MediaPlayer, so I cannot see if those shadows are on the AVI file.
    Anybody has any suggestions on how to avoid those unpleasant shadows?
    Thanks!
    Bye bye,
    Massi.
  2. Member rhegedus's Avatar
    on the jazz
    Is the avi de-interlaced?
    Regards,
    Rob
  3. Originally Posted by rhegedus
    Nope.
    The source AVI is interlaced (PAL) and the mpeg2 output file is interlaced too.
    Byebye,
    Massi.
    Jan 2001
    Brisbane, Australia
    was this capped striaght from the TV???
    or off a Video tape???
    I got a similar problem with what you described capping
    Star Wars IV from tape - the first hour or so had this motion problem and it slowly "faded" out to a normal cap - I wasn't using huffy either
