PLEASE HELP!!! I've been banging my head into a wall for a week on this problem. I've searched all the forums and read all the guides, however, I can't seem to find a solution that works.
I've got an AVI file that's been saved at 12.5fps that I want to make a VCD out of. According to VirtualDub the Video is MS MPEG-4 3688 V3 (352x288 12.5fps) and the Audio is Fraunhofer IIS MPEG Layer-3 Codec (24000Hz-Stero).
If I run this through TMPGEnc using NTSC (29.97fps) the audio/video are out of synch. I've tried saving the audio as a WAV file using VirtualDub and then running it through TMPGEnc using the AVI & WAV file, but the results are still of of sync.
What am I doing wrong or better yet... What is the right way to do this?
open in vdub then audio then full processing mode then audio/conversion
check 44100. 16 bit. hi quality, stereo. then save your wav and it will be in synch
or you can framesevre it from vdub with the above settings
Audio synch problems
By davehaze in forum Newbie / General discussionsReplies: 0Last Post: 18th Jul 2011, 07:27 -
Audio/video synch problems ... again ...
By Diana (Cda) in forum Newbie / General discussionsReplies: 1Last Post: 6th Jul 2011, 21:59 -
Audio synch problems on an .avi file -noob
By ComicFan2 in forum ffmpegX general discussionReplies: 4Last Post: 18th Dec 2008, 12:47 -
audio synch problem VOB to MPG
By ajmsnr in forum ffmpegX general discussionReplies: 1Last Post: 6th Dec 2008, 04:06 -
By zinc in forum AudioReplies: 4Last Post: 6th Jul 2007, 22:22
