I have ripped DVDs using DVD Decryptor and Smart Ripper and then used IfoEdit to strip out unwanted clips and also have it create new IFO files. I then use RecordNow Max 4.5 to record and these DVDs play in everything including XBOX.
Here's the problem, If I take the same VOB files and try to import them into Gear Pro DVD I get a load address error and will only load the VIDEO_TS.IFO and VIDEO_TS.BUP files. It won't add the rest of the files and I can't burn my DVD.
Gear Pro requires everything to be 100% ok otherwise it won't let you burn so I think that there is something wrong with the IFO files that IfoEdit is creating. Even though I have burned the disks using other software. Gear Pro supposedly creates 100% compatible DVDs, that might be why Gear Pro won't work while others do as others are not 100% compatible.
When I don't create new IFO files, for example when an entire DVD will fit onto 1 DVDR, Gear Pro doesn't give me these errors so once again it is something with the way Ifoedit is creating the IFO files.
Is there another program I can use to create the IFO files for the main movie without authoring or is there an option in IfoEdit to fix this?
Any experienced suggestions are appreciated. Thanks.
Results 1 to 1 of 1
winavi 8.0 access violation error address 0000000 ??????
By confundido in forum Video ConversionReplies: 5Last Post: 24th Jun 2010, 22:14 -
Start sector question in GEAR PRO
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 22nd Nov 2009, 15:23 -
Problem editing IFO using IFOedit
By cooldude859 in forum Newbie / General discussionsReplies: 4Last Post: 5th Nov 2009, 17:54 -
Create IFO from VOB w/o IFOEDIT?
By theschles in forum Authoring (DVD)Replies: 1Last Post: 1st Nov 2008, 19:19 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 14:38
