beter quality than 2 pass? 1 pass?
Generally, yes. When you use VBR the encoder attempts to allocate the bitrate to where it is most needed, so it will apply less in flat, low motion scenes and use this bitrate saved to apply it in fast motion scenes. In
1-pass VBR the encoder is making these decisions as it encodes, relying on past data already encoded to make future decisions. Believe it or not, with 1-pass VBR the last half of the movie should be higher quality than the first half, because there is more data to analyze.
With multipass VBR the encoder scans the entire video first by making a test encode. It gathers all the information it needs first, then starts encoding. Of course there is always room for error so by scanning it again and again with additional passes the encoder gets more accurate information and further refines the allocation of the bitrate. According to CCE, the maximum level of efficiency is reached between 3 and 4 passes, so beyond this probably won't have any effect on quality. Also note that the first pass must makes the VAF file, so if you set CCE to 3 passes you are actually doing 4.
The benefit gained from additional passes is largely dependant on your source but generally, more passes will equal higher quality, if you can live with the longer encoding times. -
thanks!
wow...only the vaf file take me 1Hr....so baisicly the encoding will be 1Hr to right? -
Right. Each pass takes roughly the same amount of time. But the amount of time it takes to do the encoding stage will depend on how many total passes you have. So if it took 1 hr to do the vaf and you are doing 2 pass encoding (actually 3 including VAF) than it will take 3 hrs total.
mmm...its only 2hr...
cool...
I have Dual CPU system, there is effect on the encoding right? -
I tried the dual gig but It didn't turn out as good I tought it would .
Older versions of cce I think aren't optimized for bridge support.
It also might depend on the type of bridge ( amd/intel ) and the version of cce you're running.
For me 2.53 with dual celerons didn't quit make double speed...Anyone tired of his old DVD burner? Why put it into the trash? Contact me! :)))) -
well i just finished (DVD2DVDR) 3.2GB movie, great quality 2 Pass VBR
and i have enough space for the original menu...
advantages of encoding vob/mpeg2 to h.264 using 3-pass instead of 2-pass
By codemaster in forum DVD RippingReplies: 8Last Post: 21st Sep 2011, 22:11 -
Technical Query Re Reading of 1st pass stats during second pass xvid encode
By onesikgypo in forum Video ConversionReplies: 1Last Post: 13th Mar 2011, 07:59 -
Does powerdirector have 2 pass VBR?
By perfection in forum Newbie / General discussionsReplies: 1Last Post: 25th Jul 2009, 00:49 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 04:55 -
DVDA 4 can do 2-pass VBR?
By itsme1 in forum Authoring (DVD)Replies: 4Last Post: 15th Jul 2007, 00:24
