if im using DVD2ONE and than copy the vobs to the original movie dir
and use ifoedit...than i can remove the vts_02_1 without updating again the ifo?
Vague question, need more info?
vts_02_1 could be anything, could be the main movie could be a trailer or extras. Go into DVD Decrypter and select MODE File F, and make sure under EDIT that 'Select main movie files' is hilighted. This will then tell u the vob's needed for the main movie. If you want to see what each vob is, just double click it and Windows Media player 8 will run it (Windows XP, not sure about other OS's)
Hope that helps...
rhuala
DVD Shrink structure problem
By janefield in forum Newbie / General discussionsReplies: 5Last Post: 14th Jun 2010, 09:11 -
DVD structure
By gbabione in forum DVD RippingReplies: 6Last Post: 19th May 2010, 23:41 -
Change DVD link structure (i think)
By nOmArch in forum Authoring (DVD)Replies: 0Last Post: 4th Apr 2009, 11:09 -
HD DVD Disk Structure?
By wulf109 in forum Blu-ray RippingReplies: 4Last Post: 7th Jan 2009, 00:58 -
create dvd structure from a .vob
By forare in forum Newbie / General discussionsReplies: 6Last Post: 12th Sep 2007, 04:13
