I am currently trying to write a DVD rip to VCD with TMPGEnc, but the film's the size of a TV, not widescreen.
I know it looks good in widescreen mode when I watch the film with PowerDVD, but how would I go about shrinking the image to a more widescreen like size (black borders) so that the output MPEG will look like it's playing in the correct aspect ratio?
I've tried clip frame but the black borders cut parts of the image off.
Thanks for any help I recieve.
Try the Settings button, Advanced tab and change the Source Aspect Ratio to 16:9 (NTSC or PAL)
encode a few minutes of the film and see what it looks like... -
Still looks the same when I try "16:9 625 line (PAL)" and "16:9 Display".
Here's a screen grab I took, if it helps.
http://homepage.ntlworld.com/jonty_amiga/Example.JPG -
you need "Keep aspect ratio" as wel las 169 display.
when you have changed the source aspect ratio to 16:9 PAL 625 does the output not look differently (with borders) in the TMPGEnc preview window?
(I've just done this a dozen times fritting between 1:1 and 16:9 and it works for me?)
Also, in WMP press Alt+Enter for full screen effect to see the borders, dont view it in a window -
I normally do watch films in full screen, but I decided to take a grab of the window so that you can see the size of the image properly, but anyway, it's sorted now.
One more question, what's the difference between the two different full screen keep aspect ratio video arrange modes?
Dvd player plays widescreen dvds in fullscreen on widescreen tv
By Fireworks_at_Dawn in forum Newbie / General discussionsReplies: 35Last Post: 24th Sep 2012, 08:24 -
How to fullfill a widescreen video (4:3) into a widescreen project (16:9)?
By coxanhvn in forum Newbie / General discussionsReplies: 8Last Post: 10th May 2011, 11:59 -
Anamorphic widescreen with TMPGenc Author Works 4
By jakewoodblues in forum Authoring (DVD)Replies: 1Last Post: 23rd May 2010, 02:26 -
Convert letterboxed widescreen to anamorphic widescreen?
By ziggy1971 in forum Video ConversionReplies: 6Last Post: 7th Mar 2008, 22:15 -
getting rid of black borders from ripped widescreen movies?
By curt1sw in forum Video ConversionReplies: 12Last Post: 20th Oct 2007, 04:35
