Hi!
Im wundering if there are any way of getting Panasonic MPEG enconder work with Avisynth script including plugin for subtitles thruu textsub.vdf?
Yes the Panasonic encoder does work with AVISynth.
Just write your AVISynth script and when you select the video file
from within the Panasonic encoder, highlight 'All Files' and point it to
your script 'whatever.AVS' (the .AVS file being your AVISynth script)
I use the encoder with Avisynth for all my VCD's and I know
it works with the Panasonic Encoder version 2.30 and 2.51
Regards
Waylander
Capture AT&T (ATT) Uverse video signal & AT&T Uverse DVR programs
By bluehan2010 in forum Capturing and VCRReplies: 1Last Post: 23rd Apr 2010, 10:40 -
FAVC envoder error
By KnightHeart in forum Video ConversionReplies: 4Last Post: 13th Jan 2010, 17:45
