I'm going nuts. I think I've tried every trick I found on the website and followed every guide there is on vcdhelp.com. The problem is this: I'm trying to convert a downloaded Divx to VCD. I also want to add dutch subtitles to it. When I convert the Divx to VCD without subtitles all works well.
But, when I convert the Divx to VCD with subtitels the sound is going out of sync.
This is the process I used: Split the sound from the Divx to .wav with Vdub -> convert the subs from .srt to .ssa -> use vdub frameserver for adding subtitles -> use tmpgenc to convert the Divx (via vdub frameserver .vrd) to VCD. I've used the same fps (23,976) for both input as output.
When I look at the mpg Tmpgenc created, the first 37 min. are going just fine. After that there is a minor distortion in the video which seems (?) to be the reason for the sync problem. After that the difference between audio and video is about 5 sec. The distortion is also present in the original Divx and it doesn't give any problems at all there.
I really don't know what to try anymore and all my hopes are on you guys. I hope someone can help me to solve this.
Regards,
Ramon
you could try to correct the file, I think it wont be easy
Or you coulkd try to convert the part before this X and then the part after the X. You can join mpegs afterwards.
Cut the divx with vdub, the subs with subtitle studio ( cut+convert in 1)
Did you check the video stream for errors? ( vdub)Anyone tired of his old DVD burner? Why put it into the trash? Contact me! :)))) -
Hi,
I did check the stream for errors and it came up with none. I tried to correct de divx by cutting the distortion, but like you said, it was very hard to get it right again. I've also noticed that when I split the audio from the video that audio time is shorter then the video time. Streching the audio didn't do any good, it was still out of sync. It's a weird problem and I think I'm gonna throw the towel.... -
maybe you should download the movie again
SorryAnyone tired of his old DVD burner? Why put it into the trash? Contact me! :))))
problem with Srestore (or something) script in Vdub
By spiritgumm in forum Video ConversionReplies: 9Last Post: 21st Apr 2011, 19:32 -
VDub + TextSub + multipass problem
By Keeyu in forum SubtitleReplies: 3Last Post: 14th Jan 2011, 10:11 -
VDub Problem
By heygurl in forum SubtitleReplies: 8Last Post: 9th Dec 2010, 19:38 -
VDub - Frame Size Problem - Huffyuv-2.1.1
By cnolan011 in forum Capturing and VCRReplies: 8Last Post: 24th Oct 2008, 21:54 -
Vdub problem
By RR420 in forum Capturing and VCRReplies: 0Last Post: 8th Mar 2008, 14:43
