How does a vcd work on a vcd/dvd compatible player?
Do you just download your files on your cd and it should play onto a compatible player??
When a vcd is playing through your tv via a vcd/dvd player, can you tape from the vcd that goes through your tv onto a video tape??
No. Read the What Is and How To's!Do you just download your files on your cd and it should play onto a compatible player??
Yes. There's no MacroVision or other nasty stuff on a VCD.When a vcd is playing through your tv via a vcd/dvd player, can you tape from the vcd that goes through your tv onto a video tape??
/Mats -
Can someone tell me what I need to do to my vcd to allow it to work on a vcd/dvd player?
Please place a link below -
If you already have a VCD, and your player handles VCD, you don't have to do anything besides putting the VCD in your player.
If you have a VCD compliant mpeg file, you have to author it to VCD using VCDEasy and then burn, again using VCDEasy or Nero.
If it's not a compliant mpeg, or a video file of some other format, it has to be encoded as a VCD compliant mpeg using TMPGEnc (or other encoder), then authored and burned (see above).
All this has been described a zillion times in the past (Use Forum Search), and is covered in almost as many HOW TOs here at this site.
/Mats
Video from PC encoded and Burnt to VCD to Play on my DVD R Player
By dashas in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 22:15 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
GPX D1816SIL dvd player and I can not use it to play VCD disk.What should I
By nyankum in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jul 2008, 13:15 -
Upconversion DVD player w/ S/VCD
By Clessoulis in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th Feb 2008, 10:43 -
vcd playback - flickering picture on one dvd player, fine on another
By i_ming in forum Newbie / General discussionsReplies: 5Last Post: 21st Oct 2007, 08:41
