Hello.
I have a problem currently. I have downloaded an MPG file. It is not a VCD compliant MPG.
I believe it is a CDi MPG. How do I convert it? I know I could simply turn off the VCD Compliance in Nero but the file exceeds 80 minutes, soI would like to be able to convert it so that I could split the file.
Thanks in advance.
Yours,
Beev -
Try remuxing the mpeg as VCD (Non Standard) with MPEG Tools in TMPGEnc, and then author with VCDEasy.
/Mats -
"Try remuxing the mpeg as VCD (Non Standard) with MPEG Tools in TMPGEnc, and then author with VCDEasy."
How do I remux the VCD? I will have to download VCDEasy too.
Thanks for the help.Yours,
Beev -
- Start TMPGEnc.
Select MPEG Tools under the file menu.
Select the Simple Multiplex tab.
Select MPEG-1 Video CD (non-standard) as Type:
Select your original MPEG as both Video and Audio input.
Select destination file name for your output.
Click on "Run"
Take a small cup of coffee.
Now you have an mpeg that ought to be possible to use as source material for a XVCD.
Depending on what your DVD/VCD player can play, you may end up with a XVCD that works for you. If not, then reencoding with TMPGEnc (or other encoder that can take an mpeg as input) to VCD compliance is the only path left.
/Mats - Start TMPGEnc.
mats,
I finally got round to trying your method. Im afraid it didnt work. It stopped at around 12 minutes into the mpeg and gave some starnge error. I cant remember what the error was but I will post it later.
Thanks for the info so far, its much appreciatedYours,
Beev -
Then there's probably a bad file. You could try some other app, capable of remuxing, like bbmpeg, even if that's not as "intuitive" as TMPGEnc...
/Mats -
Load it into TMPGEnc. Select the VCD template, then encode it.
Hello.
[FFMPEG -> VCD-MPG] How to push CBR?
By Gew in forum Newbie / General discussionsReplies: 4Last Post: 13th Apr 2009, 10:05 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56 -
I used Super to convert AVI to mpg VCD...........................
By videonewbie69 in forum Video ConversionReplies: 2Last Post: 23rd Jul 2007, 12:34
