I have a nice new P-III 800 MHz laptop with all the goodies and want to video edit. Trouble is finding a way to capture my video from a VCR. I have a Dazzle DVC USB, which gives me MPEG-1, but is pretty crappy quality.. I've captured/converted the MPEG-1 at the highest quality possible, but it still looks bad.
I want to get good quality MPEG-2, but don't know how. I know I can't do it with my current hardware.
Please help!
---John
Can't use a PCI card... laptops don't come with one! The only thing I can use is a PCMCIA card, but Firewire is only for digital video capture. I'm capturing analog from VCRs etc.
I'm in the same boat as you - I have a laptop and Dazzle USB. As you say the quality is not brilliant. If I had the money though I would buy Dazzle Hollywood Bridge to convert analogue video to DV and connect to the laptop via firewire
If you check out this site it may have what you are looking for.
http://www.shipitforyou.com/cgi-bin/sgin0105.exe?TRAN85=Y&GENP=&UID=2001100213411244&T...45+1002&FNM=21
Then check cdw they have it for under $100 US.
I was lucky enought to get a laptop for work that has video capture built in.
Ignore the above link unless you are looking for a mac. Sorry, Missed that req.
Mpeg-4 stutter freeze on laptop 1, laptop 2 plays fine- why?
By sevenofone in forum Software PlayingReplies: 1Last Post: 8th Apr 2011, 16:15 -
Advice: To make my Laptop edit better.
By Cvintila in forum EditingReplies: 14Last Post: 9th Oct 2010, 21:57 -
Formatting laptop, how do i know if a laptop has wifi capabilities?
By ricardouk in forum ComputerReplies: 8Last Post: 21st Nov 2008, 09:24 -
DVDs work in desktop PC but not in laptop - previously worked in laptop
By Brent Jewell in forum Newbie / General discussionsReplies: 3Last Post: 6th Nov 2008, 19:40 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 10:38
