If I capture a CVD-compliant MPEG-2 file from VHS source material and burn it to a CD-R, can I easily rip and recreate the MPEG-2 file from the CD-R at some point in the future when I finally get a DVD writer and consolidate the contents of a half-dozen CVDs onto one DVD-R without having to do anything massively time-consuming? Put another way, if I have a CVD with five tracks, is there an easy way to rip those 5 tracks back into normal MPEG-2 files, ready to burn onto a DVD-R as 1/2 DV1(?)-resolution video (possibly with a detour along the way to resample the audio)? Or does the act of authoring the CVD irreparably mangle the MPEG-2 files written to the disc so they can't be recreated at a later date?
I do it that way:
I rip the mpeg 2 files from CVD
I re-mux them as mpeg 2 VBR (not mpeg 2 VBR SVCD!)
I load the files to Unlead.
I make the menus, etc
I burn
If the audio is 48khz and the Video 352 X 576/480 with the correct GOP structure, you don't need to re-encode anything.
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 15:52 -
newbie want to rip some vhs into DVD
By bambam in forum Capturing and VCRReplies: 5Last Post: 1st Jan 2011, 02:35 -
How do I rip a dvd made on a VHS-DVD recorder?
By dvruser in forum Newbie / General discussionsReplies: 6Last Post: 29th Jan 2010, 12:19 -
DVD-rip compared to VHS
By Digiface in forum MediaReplies: 7Last Post: 4th Aug 2008, 12:34 -
Quality loss VHS > CVD, DVD
By rglmrj in forum Video ConversionReplies: 15Last Post: 1st Jun 2007, 12:13
