I just got my DMR-HS2 and have been copying my VHS tapes to the hard drive and then editing out the commercials. I have also taped a show directly from the satellite to the hard drive and edited out the commercials from that. What I noticed when playing the edited programs is that right before where a commercial was cut out the audio is missing for a second or so. The video seems to be edited just as I planned, but the audio cuts out early.
In other words, right before the commercial break a show had a voice that said, "stay tuned for ... when we continue". I cut the commercial out and now it says "stay tuned for ... when we cont". The picture keeps going for about a second before the cut.
Has anyone else noticed this?
Results 1 to 30 of 34
Actually, someone who was not a member of this forum and therefore couldn't post, answered my question in a private e-mail.
All you have to do is go to set-up and turn seemless play "OFF".
When you do this, the playback of edits and playlists will have a tiny pause at the end of scenes, but there will be no audio loss. Even though this setting is essentially a playback option, due to the fact that the program actually plays as it records to the DVD this setting does, in fact, change the way the recorder puts the programs on the DVD.
If you are editing out commercials this pause is not a problem because the screen is probably black anyway.
I would love to take credit for this find, but I cannot.
On another note, I do find it strange that the only person willing to help me on this wasn't even a member of this forum.
Lenny -
but thats really not a slovent for the issue either. Now you are faced with another problem,
A: do you want precise edititng but with a second of sound loss
or
B: do you want small pauses at edit break
granted commercials are fine with option A, but if im lets say doing a homevideo choice A sucks and choice B is not a picnic either, espically if you are doing quite a number of edits. This keaves you with whatever you think the lesser of the two evils are.
With this in mind, at times like that i run the clips into my pc and then burn them onto dvd that way. As i can truly do real editing on the pc without any problems. Im sure if panasonic made a firmware update they could probably fix the issue. -
Coupla q's:
I don't think I'd noticed the audio problem, because so far, I'd only edited commercials. I purposely stop and end everything on the "blackouts." But I admit as some of these stations get cutesier and cutesier, they seem to skip those sometimes. One thing I haven't been able to decide is exactly WHICH frame the cut occurs at. That is, on my PC editing system, it TELLS you, that the frame you "cut" at the beginning WILL be in the final clip and the frame shown as the cut site at the end will NOT. Nowhere have I found that kind of info. So those of you with the cutoff audio ... can you you clue me in??
Second ...
mazinz: Exactly HOW do you run the clips into your PC? Doubt I can do it any time soon (short of playing a burned DVD into the PC), since the 2 machines are on opposite ends of the house and my PC s/w doesn't suppport VBR (yet), but for future reference. Those crappy menus are starting to really bug me!
NLE -
i use a dazzle 2 (dvc2) capture card (its an internal pc1 card). i just hook my video into that and capture. it cpautres in mpeg 2 format, and offers up to a 10 bitrate if needed. using that and my panasonic's tbc i have been making flawless dvds
it cuts the audio right before your edit, so if the last frame is me walking, then the next frame is black, i cut it at the black,. Once done the audio right before my edit gets cut (actually less then a second but you know what i mean) and it will do the same for wherever i end the edit as well.
NLE -
Captain Satellite,
I really appreciated the info and did in fact email you to thank you on February 4th. I don't know why you never got it, but here it is:
Date: Tue, 04 Feb 2003 01:34:39 -0500
Subject: Re: HS2 audio drop
To: CptnStlite@aol.com
Sam,
Thanks for the info. That worked perfectly. I love it. I wonder
why they made the default with it on. It is much better off.
Again,
Thank you very much.
Lenny -
You're welcome, Lenny. When I first edited and played it back, I had already decided to return it when I heard the results. I then 'RTFM' and have been digging it ever since. So Teles and the HS-2 for you as well, eh? 8)
The innaccuracies in the editing are related to the GOP (Group Of Pictures) structure of the MPEG format. Each GOP is about 15 frames, and your edit point will actually be the closest end/start of a GOP rather than the frame you select, IIRC. So, at worst, edit points will be around 0.5 seconds out from the actual cut you made. Without seamless play, the last frame from the last GOP is repeated up to the edit point, giving the 'pause' effect of a still image. With seamless play switched on, some clever stuff must go on the avoid this, but not clever enough to deal with the audio correctly too. Short of offline editing, where the whole program is recreated after the editing, I dont think theres not much more that can be done about this. On the PC, the whole shebang is re-encoded after the editing, creating new GOP's, so this issue is avoided.
Originally Posted by eeit232
At most you could lose 7 frames, which for PAL is 1/25*7 seconds, or 0.28 seconds, so my original guess of 0.5 was a bit rough. In my experience, its usually much less than this, and barely noticeable. What really bugs me is when some programming doesnt bother with fades to black before the adverts or channel logo, which makes it much harder to get a good edit point! It would be interesting to know exactly what goes on with 'Seamless play', not that anything short of a firmware patch is going to improve this situation
Hey NLE 1,
yes it would be differnt in the snese that instead of running it into your homdeck recorder, you run it into your pc and you can truly edit without any problems and it looks better. the homedeck machiens are very good but still not as good as using the pc. The panasonic still gives many artifacts and othet things i otherwise do not get when running in the same source to the pc instead.
So yes it would be different in that respect -
Originally Posted by mazinz
firstly do not take this like am i yelling at you, i had a lengthy arguement with someone about this on another board. I have been into this for years and i trained my eyes to know what to look for.
i used to own the dmr-e20, i now have the dmr-hs2. Most of the time the machine would give very hard to see but apparent artifacts, from every source (dvd, laser, etc) i was making dvds on the pc first and then the homedeck machine. if you do not know what to look for, you will always think it is crystal and this is not the case. Even times when their is no apparent artifacting from the source sometimes inbetween scenes for like a micro of a second you would get what i call the "living mass" where it
looks like a mass of something is moving on the still pics of the background of the scene.
Again you have to look hard but the machine does give these and the pc way does not. trust i have looked into this time and time again, i know what i am talking about. thanks--
PS the machine will do things like this for about 98% of material it records, every now and then you do get somethings that go through fine -
OK, you have to "look hard", "know what to look for", and you own the DMR-HS2, that's good enough for me!
yes and it is obvious you do not know what to look for otherwise you would see some of things that i do.--thanks
And in all seriousness have you ever made a dvd using a computer or have you just used the homedeck machines? Using and owning both i see the benefits and faults of them. And i also see the difference in quality of capturing through the pc and recording the same item from the same source using a homedeck machine. -
funny but you still havent given any valid reply to any questions i asked you, perhaps it is because you do not know and have nothing of merit to reply with-- well if you are satisfied with your results thats fine.
I own the homedeck machine for sake of convience 9and getting use of it's built in TBC if you know what that is) and it's results are good i was never saying they were horrible, but the PC still (or at least my capture card) gave better results than any homdeck machine i have tried out. have fun -
Uh, gee, duh, no, I don't know what Time Base Correction is.
im sure a simple search on here gave you the answer as you had not answered anything else.
look its ok to be in denial.....but maybe when or if you get a capture card and dvd burner for your pc you will see the differences that i and others do see between the two. have fun- being new to the hobby is fine, but you still have a lot to learn
funny, i too have close to 300 if not more laserdisc, i also happen to be 30, im sure im a bit older then you---
Panasonic DMR-HS2 power on failure
By rmhartman in forum DVD & Blu-ray RecordersReplies: 1Last Post: 3rd Feb 2012, 14:19 -
Panasonic DMR HS2 (Setup Mode?)
By philo in forum DVD & Blu-ray RecordersReplies: 2Last Post: 4th Jun 2009, 12:14 -
Panasonic DMR-HS2 - shuts down when I try to record
By donmeyer2 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 4th Sep 2008, 22:35 -
Problem with Panasonic DMR-HS2
By rmhartman in forum DVD & Blu-ray RecordersReplies: 3Last Post: 20th Feb 2008, 15:07 -
Help ! - I can't get my Panasonic DMR-HS2 to open - crazy machine......
By agent31 in forum DVD & Blu-ray RecordersReplies: 6Last Post: 13th Sep 2007, 02:12
