Or a movie that is on 2 DVD like Pearl Harbor or LOTR?
I have been playing with VobEdit and InfoEdit and so far eveything I do gets me wierd output with screw up chapters or incomplete movies...
I want to produce a set on vobs on my HD that DVD2one will be able to process.
thats easy... put all the VOBs in one directory.
make sure u rename them in numerical order... start from the first vob on the first disc - pick up where u left off on the first disc and continue numbering on the second disc.
then use ifo edit
then dvd2one
then burn! -
then use ifo edit
Another problem I have with Pearl Harbor is that I have 12 vobs, so how do I rename them? -
yes ... delete all the other ifo or bup files and create a new ifo for you vob files because in essence u are making a new dvd!
I have tried VTS_01_01,02,.. not working, getting message "Cannot find any VOB unit in VOBS file". Same with VTS_01_001, 002,...
What I am attempting now is this:
1 - Used DVDDecryptor to RIP both DVD to 2 folders
2 - Stripping 2 audio files from both set of VOBs with IFOEdit to reduce the size. (Went from 12 VOBS to 10 VOBS, 2 of them not full)
3 - Rename all VOBS to VTS_01_001, 002...
4 - Join the VOBs with VOBEdit. (got 9 vobs now)
5 - Make IFO file from the VOBEdit output
well that didnt work... giving up on this
How can I join two sided dvds.......................?
By forest.lawn in forum Newbie / General discussionsReplies: 1Last Post: 17th May 2011, 18:51 -
Double-Sided, Dual-Layer DVD media?
By dgpretzel in forum MediaReplies: 22Last Post: 15th Apr 2008, 15:03 -
Dual-Layer Double-Sided DVD's turnover?
By Deisel Weisel in forum DVD & Blu-ray RecordersReplies: 6Last Post: 22nd Nov 2007, 21:23 -
do they sell double sided, single layer dvd's (DVD-10 - the ones you flip)?
By cduval04 in forum Newbie / General discussionsReplies: 12Last Post: 24th Oct 2007, 10:40 -
How do I convert double sided dvd to dual layer dvd?
By acid_burn in forum DVD RippingReplies: 2Last Post: 22nd May 2007, 04:04
