I have hardware mpeg encoder card, in manual tell me that can make this mpeg 1 file in VCD1.0 video quality
I try to encode mpeg 1 with
-video bitrate 2400 kbps ,352*288 25fps PAL
-audio bitrate 224 kbps ,44100 Hz
This mpeg file can play fine
After I use Nero 5.5.4.0 to burn it
I deactive "complin standard CD"
In nero window does not show "duration" of mpeg file
And i burn it success
But My XVCD can not play on my PC with powerdvd,windd,media player and ...
What wrong with Me!
My system
Pioneer dvd 10x
PIII 550 ram 128MB
Hd 20 Gb 7200rpm
Sounds like a region problem to me. What country are you in?
If the PAL/NTSC setting is the problem, DVD Genie, or DVD Region Killer (http://www.tweakfiles.com/) should solve the problem.
Hope it's that simple
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
nero crashed during burn
By mr-scarface in forum Authoring (DVD)Replies: 13Last Post: 14th Jan 2009, 23:41 -
Can't burn video TS with nero
By anfield7 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Dec 2008, 03:19 -
NERO burn error
By Budokhan in forum Newbie / General discussionsReplies: 2Last Post: 13th Jul 2008, 21:58 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11
