  1. I have several .dat files that were extracted from a .bin and .cue file. I tried to convert them to mpeg but with no success. I keep getting a no audio message on my Sony NS715P player. Any suggestions? I burned the original .bin and .cue file to a CD and the that is where the .dat file came in to play.
  2. What i normaly do is just change the .dat to .avi and play it with mediplayer or winamp with correct codec
  3. hi,
    check out VCDEasy. the dat->mpeg utility bundled in the
    program is the greatest one I've tested. You get back every
    single byte!
    greetings,
    sunmanking
  4. Member mats.hogberg's Avatar
    Jul 2002
    Sweden (PAL)
    Renaming .dat to .avi may work, but a VCD .dat file sure aint no .avi - it's an mpeg file. The difference are some header info. In addition to VCDEasy, VCDGear can "convert" .dat to .mpg
    /Mats
  5. hi,
    yes, vcdgear can do it too. BUT and this is a big *BUT*...
    vcdgear will not give you back the same bytes as the
    original mpeg file. that is a matter of fact. I've tried it
    with many different mpegs and vcdgear will fail. on the
    other had, vcdeasy works FAULTLESS. what a work of
    art
    greetings,
    sunmanking
    May 2002
    Rainy City, England
    Rename the .dat to .mpg. Then use TMPG's mpeg tools to multiplex (Type MPEG-1 Video-CD), and output with a new name. Burn this to VCD with something like Nero.
