OS: Win XP
Captureing an Analog Hi-8 via Firewire using a Digital 8 cam.
Software: newDVD, DVIO
Problem: It captures upto 4GB and then stops. Is there a way in which I can capture beyond th 4GB limit without having to manual intervention
Results 1 to 9 of 9
check your hard drive partition where the captures are going--if its fat32 you will either have to make sequential captures or switch to the NTFS file system. I did that and haven't looked back.
Also make sure that you have DVIO set to use type-2 DV files. Right click the title bar and set file AVI format to type-2.
thanks you for your suggestions.
I tried capturing it as Type 2, but the problem is that the resulting AVI file is not recognized by tmpgenc. -
Originally Posted by touche64
Do you have the proper codecs installed? -
Also, what is the difference between Type 1 and Type 2. I am assuming Type 2 is a later version.
Do u know what the pro's are for Type 2 -
Check this for more info:
http://www.puremotion.com/videoediting/reference/technical/2gbfilelimit/ -
Thanks, that was helpful.
Apparantly, Windows Movie Maker uses a different algorithm to create an AVI file. where can I find a codec to use with tmgenc?
How to make AVI file to 1.4GB ?
By zovx in forum Video ConversionReplies: 2Last Post: 5th Feb 2010, 10:24 -
help -- salvaging a 4gb avi file
By pkpara in forum Newbie / General discussionsReplies: 3Last Post: 24th Aug 2009, 20:50 -
Shrinking an AVI file from 1.4GB to 700MB
By DVantrease in forum Video ConversionReplies: 5Last Post: 28th Mar 2009, 19:11 -
Extraction of raw A/V from AVI container for files >4GB?
By alfonzo in forum Video ConversionReplies: 22Last Post: 11th Sep 2007, 07:18 -
4gb Limit on SDHC Card, FAT32
By AVCHD in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 04:24
