I'm fairly happy with the DVDs I've ripped into VCDs. The quality is pretty decent. The only thing I don't like is the blockiness that shows up mainly on dark or wooden walls. Outdoor scenes are great. I'd like to keep it VCD compliant. I've read around and I think it's called DTC block. Other than that they are fine. I'm using DVDx to TMPGenc. Is there a way to use one of the filters in TMPGenc to get rid of these blocks? Does using the filters in TMPGenc slow encoding time? I've read all the guides I can find, but none of these guides goes in depth on the filters. TMPGenc could really use a good help file. Anyone know where I can find a more in depth guide on these filters? Don't ask me to use filters in avisynth, as avisynth completly confuses me.
Thanks so much,
Tim
Unfortunately some artifact are unavoidable at low bit rates i.e. vcd, though filters may help u problem they cause problems of their own & will increase encodeing time u tried svcd or cvd these give alot better results in my opinion
Encoding with 2-Pass (VBR) can effectively remove blocks.
Hey puertorican 138:
Can you not soften the block noise under the quantize matrix tab?"Art is making something out of nothing and selling it." - Frank Zappa -
he said he wants to keep it compliant, so VBR is out. altering the Q matrix to use the kwag template value would help, but i don't know if VCD spec has a limit on GOP length, i know DVD is set at 15(pal) and 18(ntsc) is VCD set?
@flaninacupboard,
The New KVCD BETA-1a "Notch" Q. Matrix should help, even with a standard CBR VCD. It will reduce many of the visible DCT blocks seen on dark areas of the picture.
@puertorican138,
Soften block noise doesn't work correctly in any version of TMPEG above 2.x. The higher you increase the intra block and non-intra block numbers, the sharper the edge of the blocks, and the more visible they are. If you leave it unchecked, it produces a more natural and softer effect. The opposite as advertized
-kwagKVCD.Net - Advanced Video Conversion
http://www.kvcd.net -
what about using avisynth...I have learned a LOT from hanging around at kwag's site..I actually had a dark movie come our pretty good with filters.....I was very impressed.
scott
How to get rid of these color blocks?
By protoX in forum Newbie / General discussionsReplies: 3Last Post: 5th Feb 2012, 10:10 -
Blocks after burning Imgburn
By Russo in forum Newbie / General discussionsReplies: 9Last Post: 27th Aug 2011, 20:31 -
Blocks in dark areas
By santosx in forum Video ConversionReplies: 22Last Post: 12th Oct 2010, 19:54 -
:?: Vegas Pro 8.0 - How do I get rid of these "blocks"?
By YouTubeHDHacker in forum EditingReplies: 1Last Post: 6th Dec 2008, 17:19 -
blocks in dvd?
By wingfan in forum Newbie / General discussionsReplies: 7Last Post: 10th Nov 2008, 11:25
