I see people are setting this to 112k all over the forum... so I thought I'd try to get a straight answer.
What does this help? Or, Effect? Would you use this wityh a VBR MPEG-1 encode? Can You?
Sounds like a newbie questionbut I am curious to know the answer to it, plus I have a "problem" movie I want to see if this helps.
Side question... which is better for SeVCD, VBR (with a low AVG but HIGH MAX), or CQ_VBR (which has a low MAX, but "constant quality", whatever that means). The "Problem" movie is experiencing times of stuttering motion scenes, with HIGHEST motion search activated... thanks on someone answering this one, too...![]()
Results 1 to 1 of 1
YouTube Buffer Speed
By gooberguy in forum ComputerReplies: 4Last Post: 25th Feb 2010, 22:12 -
Buffer Device question:
By butt_crack in forum DVD RippingReplies: 1Last Post: 5th Feb 2010, 12:35 -
What is buffer size?
By dzsoul in forum Newbie / General discussionsReplies: 1Last Post: 6th Dec 2009, 10:04 -
chunktab buffer too small?
By 820am in forum ffmpegX general discussionReplies: 1Last Post: 21st Dec 2007, 13:57 -
Buffer overflow in tmpgenc?
By themaster1 in forum EditingReplies: 7Last Post: 15th Jun 2007, 17:08
