This is probably in one of the guides, but I cannot find it.
Recently changed my VFAPI plug-ins and screwd them all up. Now all my mpegs are invalid (or at least screwed up) when burning with Nero. MPEGs burn fine with VCDEasy, but when burnt with Nero, the result is an dat file with bad integrator. VCD says "strange (possibly non-compliant) user_data seen... (not a problem, usually a sign of TMPGEnc)", but burns it okay.
My version of TMPGenc (v2.54) does no offer the return to default setting. Can someone plz tell me what the defaults are???
Here are my current settings:
DirectShow MultiMedia File Reader = 1
AVI2 File Reader = 0
BMP/PPM/TGA/JPG File Reader = 0
Wave File Reader = 0
TMGEnc Project File Reader = 0
AVI VFW Compatible Reader = -2
Fully recognzie that there are MANY "good" settings, but these are screwed up and just need to get it workin again. Burning cds to check can be kinda expesive.
Thanx
Results 1 to 13 of 13
See if this helps
KingJohns Guide TMPGEnc Plug-in
Oh, I see you dont have a Mpeg 2 filter -
Thanx for the response. Maybe somehow my MPEG filter got lost and that the prob????
How about a really dumb ass question?
HOW DO I INSTALL THE MPEG FILTERS ????
Your guide says nothin about that -
Why do I feel so stupid atm????
Although I dont think this is my real problem (see https://www.videohelp.com/forum/viewtopic.php?t=141374), since I did not have the LSX MPEG Encoder installed, it seems like a good idea.
BUT...
I installed LSX-MPEG Encoder V3.5 but it does not show up in TMGEnc. I could run it as an external tool, but it seems to me it should be recognized in the VFAPI Plug-ins. Tried installing it in the default dir as well as in my TMGEnc dir, but still not listed in TMGEnc.
Still playin with it, but as of yet, still not recognzied -
OK,
I've downloaded the .lzh file to install a file which allows me to read Mpeg2's into Tmpgenc, what programme do I use to open .lzh files? It will not open in Winzip.
Bill -
Try Winrar, it opens everything. Available here: http://www.rarlab.com/
"Art is making something out of nothing and selling it." - Frank Zappa -
Originally Posted by LabanB
However, TMPGEnc + will only work with 3 mpeg 2 filters. Sony,Cyberlink and Ligos. Ligos should show up no matter where you install it, maybe you need to re-install TMPGEnc.
The New TMPGEnc has problems with the cyberlink filter (Power DVD 4) Ligos works fine.
Ah yes, WinRAR will open LZH 8) -
Thanx I am going to reinstall everything and see what happens. Maybe that will fix all my problems (or maybe not) - will let you know.
BTW - this izh stuff is not from the original post. think it got posted here by mistake. Making following this thread a little confusing
Thanx KingJohn 4 all ur help -
if all else fails, boot your sytem with a start-up disk, when you get an A:\>
type C: when you see this C:\> Type format c: ignore all warning messages there just BS
this should clear everything up"The software said Win XP or better, so I Installed Linux" -
Was going to format my disk like u suggested, but i told that befragging was better than formattin...
Gonna try this method - hear it works really good
http://www.datadocktorn.nu/us_frag1.php -
Originally Posted by WeBMaSTeR
Hope you get it sorted.
Any psychedelic or kaleidoscope effects plug-ins or software?
By johnharlin in forum Newbie / General discussionsReplies: 2Last Post: 26th Mar 2011, 08:57 -
Tmpgenc 4 plug-in settings cant be changed?
By mrjust in forum Newbie / General discussionsReplies: 0Last Post: 27th Mar 2010, 22:50 -
Descriptions for Audio Effect Plug-ins-- Vegas 6.0d
By solarblast in forum AudioReplies: 4Last Post: 15th Nov 2008, 22:39 -
Anyone know good Video Editing tools? Sharpeners, plug-ins, grain, etc?
By HOTPROPHET in forum Newbie / General discussionsReplies: 4Last Post: 21st May 2008, 13:04 -
I'm wanting to cut some scenes and add some fade-ins to a DVD video.
By Ryan J in forum MacReplies: 4Last Post: 17th Apr 2008, 08:42
