Hi Guys,
Just got a Panasonic A05. I have a number of MPEGs that I have used to create VCDs.
Do I need to do anything special for them to burn on a DVD? Do I need to merge them together? Do I need to reconvert them to MPEG2?
Just not sure of what is required.
You can reuse your MPEG-1 files for DVD without converting in MPEG-2.
I use Videopack 5 and it considers every file I give it to be not standard because of multiplexing. It remux the files before creating the disc image, so I think that VCD files must be remuxed as well.
Your app may do it automatically, without warning you about this problem. -
The only change you need to make to a VCD compliant mpeg-1 file to make it DVD compatible is you must re-sample the audio at 48khz. There are plenty of tools that will do this for you. It should then be accepted by any DVD authoring program. Some may do this conversion for you.
Ifoedit 0.95 can author your vcd's without the need to convert the audio,it will accept 44100 audio. since it can only process one movie you will need to join them first.
OK Thanks
In order to resample the audio, do I use TMPGENC? Open the old MPG load the DVD template and convert? Or is there an easier and/or less time consuming way? -
Use TmpGenc mpeg-tools to demultiplex the audio and video into seperate files. The take the mp2 file and use any decent audio editor (such as goldwave) to resamplr to 48khz. Save as wav. Then re-convert this wav back to mp2 using TmpGenc, HeadAc3he or Besweet. You may the re-multiplex or use a DVD authoring package that accepts seperate streams.
Hope this helps
Multiple AVI files to multiple DVD discs, no quality loss, chapter per avi
By Delta007bhd in forum Video ConversionReplies: 11Last Post: 14th Apr 2010, 08:27 -
Invalid DVD / Multiple errors with multiple programs...
By multiplex in forum Newbie / General discussionsReplies: 10Last Post: 6th Oct 2009, 15:50 -
Play multiple streams in DVD (Merge multiple streams)
By sebastien91 in forum SubtitleReplies: 0Last Post: 25th Apr 2009, 18:44 -
Authoring Multiple Language DVD with multiple language menu options
By kemimich in forum Authoring (DVD)Replies: 7Last Post: 8th Sep 2008, 16:29 -
Multiple VCDs in one DVD
By vid_n000b in forum Authoring (DVD)Replies: 27Last Post: 30th Apr 2008, 02:52
