O.K.
I own both of the above items.
Question #1:On the back of the DRM-E30 there is what looks like a small
cooling fan.
Does this thing always run?? Only run when the machine heats up??
When it does run does it make any noise?? I don't hear this thing doing
anything but I do think I feel some cool air when I put my hand by it.
Question #2:Made some VHS to DVD-R dubs for a friend.The friend has the same
Panasonic dvd player as I have listed above.
On all 3 discs the picture goes to hell(blocking,artifacts,audio
break-up,etc...) about 45 to 50 minutes in.
I bought the discs home and played it on the same Panasonic unit at the same
points with no problems.
Also tried it on my Playstation 2 and on an older RCA unit that really
shouldn't play any type of DVD-R.
They played great.
Any thoughts why two identical players would not play the same disc the same
way??
Yes it is a cooling fan unit.
Heat notice in manual says to not place dmr-e30 on top of other equipment which gets hot.
Apparently the high end of the operating temp range is 104.
I have never heard the fan run if at all when recording 10-12 hours in a row.
I cannot tell any air is moving through it at all now.
So I would say you are experiencing normal conditions. -
Well the fan is always running from what I can tell.It just runs very very quietly
Panasonic DVD & USB & SD Card Slot Problem
By Tim Sage in forum DVD & Blu-ray RecordersReplies: 1Last Post: 20th Mar 2011, 19:23 -
Best Software to Edit VOR & IFO Files from Panasonic RAM Disk & Arc
By JDex in forum Newbie / General discussionsReplies: 16Last Post: 30th Sep 2009, 06:55 -
Polaroid drm-2001g vs. Panasonic ES10
By SupaDupaMonkey in forum DVD & Blu-ray RecordersReplies: 6Last Post: 3rd Jul 2009, 01:02 -
panasonic dmr E30 compatibility
By jimakros in forum DVD & Blu-ray RecordersReplies: 5Last Post: 22nd Dec 2008, 13:19 -
Panasonic DRM-EX87 set up problem.
By Jonzjob in forum DVD & Blu-ray RecordersReplies: 3Last Post: 4th Dec 2007, 17:36
