Hi,
I got some problems with TMPGEnc Plus 2.59.
For audio encoding I use tooLame and SSRC as external tools for TMPGEnc. Now, when I try to encode a wav or avi-sound to MP2 TMPGEnc (or better SSRC/tooLame) works fine. frequency conversion works great and tooLame starts normal. Now while tooLame is encoding an error occures saying: "g:\TMPGEncTemp\mpa2_.wav can not be found".
This is during the conversion process, so TMPGEnc or better tooLame "finds" it at the beginning. What is this? Although I can't say it only happens with some special files, because sometimes it works. But if one file gets this error there is no possibility to convert it.
What can I do?????
"Ich weiß, dass sie glauben, sie verstünden, was sie denken, was ich gesagt habe.
Aber ich bin mir nicht sicher, ob sie begreifen, dass das, was sie gehört haben, nicht das ist, was ich meine." -
I already tried tooLame and had lots of bad experience with it using in TMPGenc.
My AVI's are always without audio, so I 'feed' the WAVe seperately to TMPGenc (load in as seperate audio file when loading a video).
I keep the encoding to mp2 do using the internal mp2-encoder of TMPGenc.
Despite some people claims otherwise, I don't think the results of the internal mp2-encoder of TMPGenc isn't that bad! It actually is very acceptable, if not great.
Using my mentioned method, the audio is encoded and included in the entire movie, not (when using external tools like tooLame) at the beginning of the MPeG.
Just be sure you 'feed' a 44.1Khz (16bit) audio, if you're creating a (S)VCD, it seems that TMPGenc cannot do that right... -
Thx,
I found another way do encode it right.
I use BeSweet with all external tools (SSRC, tooLAME, LAME, ...)
It makes a good sound-file and isn't that hard to handle.
I use external tools, coz I have Cinema Craft Encoder to encode videos...
Anyway, thx for your reply!!!"Ich weiß, dass sie glauben, sie verstünden, was sie denken, was ich gesagt habe.
AC3 .avi files trouble playing the sound in WINAMP
By NEVERMORE in forum AudioReplies: 0Last Post: 13th Sep 2010, 22:27 -
mp2 & wav compatible DVD authorers?
By Bassquake in forum Authoring (DVD)Replies: 4Last Post: 2nd Feb 2009, 14:11 -
Trouble opening avi in Tmpgenc 3.0 Express
By davexnet in forum Video ConversionReplies: 1Last Post: 11th Dec 2008, 11:07 -
M2V + 2 WAV files to VIDEO_TS with 2 PCM soundtracks (not mp2)
By cleantone in forum MacReplies: 14Last Post: 28th Aug 2008, 15:10 -
TMPGEnc Plus and AVI sound
By busdonic in forum Video ConversionReplies: 5Last Post: 22nd Jun 2007, 10:18
