hey, Im trying to capture audio and video in realproducer 8 using Linux. After I record a video/audio file and I try to play it, I need to turn my volume all the way up and the audio is very very hissy and bad. When I tune to a channel using XawTV, the audio sounds perfect and the volume doesn't need to be all the way up, but when I record the audio, it gets all hissy. Its annyoing because if Im just watching it in XawTV, its perfect! But any attempt to record the audio and its aweful. Im using a WinTV card. Any help would be appreciated. Oh, and I tried changing audio quality and other settings but its the same result - hissy.
Would you by chance be using an ABIT KT7(?) motherboard with a Soundblaster card?
If So, that's the problem. They've virtual dissappeared out of the computer stores here because of it.
If So, just replace the soundblaster with some other companies soundcard.
<font size=-1>[ This Message was edited by: Vidbox on 2001-09-04 01:14:57 ]</font>
AXIS P5534-E capturing video under linux
By kapone89 in forum Capturing and VCRReplies: 0Last Post: 27th Sep 2011, 10:19 -
Captured video/audio progressively out of sync (on linux)
By daytooner in forum Video Streaming DownloadingReplies: 2Last Post: 26th Nov 2009, 00:26 -
foobar2k like audio player for linux? what are you guys using?
By graysky in forum LinuxReplies: 1Last Post: 10th Jan 2009, 19:04 -
Linux themed skin for DVD Rebuilder (for Ubuntu and Generic Linux)
By freebird73717 in forum LinuxReplies: 5Last Post: 26th Nov 2008, 21:27 -
Nero Linux 3 Delivers Blu-ray and HD DVD Data Burning Support to Linux OS
By BJ_M in forum Latest Video NewsReplies: 0Last Post: 28th May 2007, 11:23
I need soemone to read this and reply
