  1. ok ive got tmpgenc v2.56. im bin trying to convet an avi file wich is 117mins long to pal dvd with the wizerd i choes to enode with vbr 3000kpps the res would b 720x576fps fps/48000 but the out put file will b way to big for the dvdr, can sum 1 tell me wot im doimg wroung plz
  2. This WILL fit on a DVd-r as long as you use mp2 or ac3 audio. If you author with MyDvd or another program that insists on converting the audio to uncompressed PCM then you will have a problem.
  3. sos y does it say its going to b to big a file
