hi folkx
i like to create a divx but it is to big for 1 cd
Writing AVI header...
Pos: 699.9s 17498f (12%) 2fps Trem:1090min 983mb A-V:0.000 [1521:0]]
the movie goes 88 minutes
4/3
pal (europe)
how can i make it small ?
sorry vor my bad english.
ffmpeg options are
video bitrate 1030
size 640x352
framerate pal (25)
codec xvid (mencoder)
audio:192 / 44hz
thank u
Hrmm
Try
Bitrate:949
Audio: 128 48khz AC3
Quantizers: Min to 1 Max to 8
That should make it smaller. And one thing about Mencoder, its accuracy on file sizes isnt really good. It goes up or down depending on what happens during the material.
Hope this Helps.
Q"Good Luck 007"
In Memory of Desmond Llewelyn -
and that means
Q"Good Luck 007"
dvd way too big?
By item9 in forum Authoring (DVD)Replies: 2Last Post: 31st Mar 2009, 00:41 -
Size is to big
By g_pentium in forum DVD RippingReplies: 9Last Post: 6th May 2008, 04:36 -
Dr. DivX output subtitles are big and blurry
By louv68 in forum SubtitleReplies: 2Last Post: 22nd Apr 2008, 13:36 -
Big big troubles with firewirre PCI card.
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 29th Feb 2008, 23:51 -
Movie seems to big
By DarkLogan in forum Newbie / General discussionsReplies: 5Last Post: 17th Aug 2007, 15:18
