As MyDVD seems to be the only reliable tool which produces DVD+RW, which can be played on my standalone, I got some questions, which aren't answered in the help file:
1. Why does MyDVD always call for uncompressed Audio and how to use compressed audio instead (if possible)
2. How can I use My DVD to burn or working on already authored DVDs (VIDEO_TS and AUDIO_TS do exist)?When I try to open open such DVD, I'm always getting a "root dir must exists" or similar error message (in German:Legen Sie den DVD Stammordner fest.Any ideas what that could mean?
You can't use MyDVD to burn a copy of the finished project
Using a dvd burning program like Prassi DVD Pro, Recordmax, etc. import the two folders into the program and burn to disc
If you don't have one of those try searching on the internet for DVD Burning software and not dvd authoring software, this should bring up several software's to do the job
MichaelMichael
Learn to create DVDs the Ezway
DVD Related Question Post them at
www.EzDVDAdvisor.com
DVD Developers Community -
The problem with Prassi is, it doesn't recognize my Philips burner.I give recordmax a try.
Mac version of VLC is less functional than the Windows and Linux version
By HitTheRoad in forum MacReplies: 12Last Post: 30th Oct 2011, 03:48 -
SUPER version 39 is broken - reinstall older version?
By castalla in forum Video ConversionReplies: 7Last Post: 3rd Nov 2010, 18:20 -
Problems with Roxio MyDVD Basic v9 and other questions
By ForgetSun in forum Newbie / General discussionsReplies: 1Last Post: 18th Dec 2007, 02:29 -
where to download old version of dvd fab??? error in new version
By willhenderson in forum Newbie / General discussionsReplies: 1Last Post: 1st Dec 2007, 16:00 -
Crop without Re-Encoding - version 0.0.9x r2 - Several questions?
By llee782 in forum ffmpegX general discussionReplies: 6Last Post: 1st Jun 2007, 00:39
