i ripped a movie using smartripper. i used dvd2avi and then tried to open it in tmpg but it wont work.
i looked around and saw that someone else had the same problem. i read the post but couldn't find the dvd2avi.vfp
DVD2AVI.VFP is found in your DVD2AVI folder. You can simply copy it to your TMPGEnc, then everything should work.
i still can't find a dvd2avi.vfp
it wasn't with the zip files.
could someone send me the file please?
The file is in the download from the link in Truman's post. Try clicking on start and doing a search for the file, if you d/loaded the zip (and extracted it) you've got the file.
every time i download the zip file, i go to extract and the .vfp file is missing. only one of the links to dvd2avi work, could it be that the file isnt included in this dist?
Certain d2v file causing problems with MeGUI Avisynth Script Creator.
By Simcut in forum Newbie / General discussionsReplies: 5Last Post: 30th Jul 2012, 16:57 -
What does Open sled. mean? & how do I find it in my D.V.D?
By cumguz in forum Newbie / General discussionsReplies: 5Last Post: 14th Apr 2011, 23:10 -
VirtualDub D2V file error
By Dr.Who in forum Video Streaming DownloadingReplies: 5Last Post: 17th Dec 2010, 14:23 -
avidemux won't open a DV .avi file
By BrianK in forum Video ConversionReplies: 2Last Post: 14th Jul 2009, 10:10 -
Nero won't open .mp4 file
By ChickaJane in forum Video ConversionReplies: 8Last Post: 21st Aug 2007, 23:38
