    Dec 2002
    Belgium
    Hi,
    After authoring I cannot use the time slidebar within PowerDVD4 anymore, while it works fine on the original DVD.
    I ripped 2 VOB files (2 seperate movies) and I demuxed to .m2v and .ac3 files.
    In DVDMaestro I created 2 Movie entiries, "Movie1" and "Movie2" and imported the files.
    I filled out the Connections tab and didn't select anything in the "Movie Properties" tab, so no useroperation should be disabled.
    When I author this I cannot use the time slidebar in PowerDVD to jump at locations in the video.
    Any ideas what I can do about this, to enable this feature?
    FWIW: the movie files do not contain chapter info, is that the reason perhaps that there is no timesearch possible?
    Thanks,
    MrSnake
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    it depends on the encoder you used ..
