I encoded a avi to mpeg2 using tmpeg extraced audio with v dub everything was fine but when i come to burn my dvd the sound is about 3 seconds out, but the origonal mpeg2 file plays fine.
Can i use the audio correct gap section in tempeg to correct this or not.
Thanx
i dont suggest that... i think it'll be easier if you get back to your original AVI
look in VIDEO -> FRAME RATE -> change frame rate so audio & video match
then check for bad frames
video -> SCAN MOVIE FOR BAD FRAMES
save as avi
and now everytin should be in place...Wanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com
Crazy Car
By budwzr in forum Off topicReplies: 0Last Post: 18th Nov 2011, 13:31 -
Fans are crazy!!
By alintatoc in forum ComputerReplies: 19Last Post: 4th Jul 2009, 06:13 -
Help, I think I am going crazy
By pfxz in forum Off topicReplies: 6Last Post: 3rd Aug 2008, 10:17 -
going crazy with editors
By ellabbs in forum Newbie / General discussionsReplies: 1Last Post: 28th May 2008, 12:06 -
This file is Driving me Crazy! suggestions plz
By k_oss_22 in forum Video ConversionReplies: 2Last Post: 19th Mar 2008, 00:40
