I tried to use the contact option on the www.dvd2one.com site and it seems that it is down.
I would like to ask your programmers to include an option where I can put in an arbitrary number of megabytes to reserve so that I may include other things on the DVD.
I have a method that allows me to keep the menu and I would like to be able to continue to do so, only I really want to use DVD2one as it is VERY FAST and I like the quality.
I just want to be able to reserve a specified amount of space for the menu and the like...thanks in advance!
i to would like to ask the programmer of DVD2ONE can you make in the new version back up menu's and also anime DVD that have episode's with a bunch of ifo file's for each episode this would be great thank you
I also think it would be a good idea to leave extra space on the disc for people that use cheep media most cheep media lock's up at 99 % of the time. by leaving extra space it make's cheep media easy to close
HERE'S an Idea Wy don't you rip an extra audio track since most dvd have many that you don' t use and then remove after Dvd2one is finished. Get A .AC3 2-chnl track they are usually only 200mb or so. Hope this helps
From dvd2ones siteOriginally Posted by spiderman2k1
Ideas for future V1.x versions:
Full disk copy. For those who want to keep those fancy menus and intros.
so I think Erwin is working on that.... -
would also like to have 2 pass encoding. But i must say DVD2ONe encoding is great I love it but would be nice for longer movies that might need a little more video encoding. Movies like three hour's or longer
from what i understand of the program there can be no "2 pass" as you call it...because the movie does not encode...it compresses
How to PROPERLY burn DVD2ONE DVD's using TOAST 6.0
By galactica in forum MacReplies: 170Last Post: 30th Mar 2012, 02:48 -
DVD2One: Unable to create vobfileset 0...
By Ryan Kelly in forum MacReplies: 3Last Post: 27th Nov 2009, 10:00 -
Weird DVD2one conversion-7 GB compressed to 2.6 GB on diskcopy, why??
By ruggerjvd in forum MacReplies: 2Last Post: 2nd Jan 2008, 10:26 -
Question about seamless joining in DVD2One
By jwnulife in forum MacReplies: 12Last Post: 20th Dec 2007, 06:03 -
Program like DVD2ONE?
By Soccerman77 in forum Newbie / General discussionsReplies: 7Last Post: 26th Nov 2007, 16:11
