i thought about something.
the whole is greater than the sum of it's parts.
would it be quicker to encode the video and then after the video finnishes the audio then multiplex.
So true! The are several guides telling you how, by example the ones Sefy has put online (see the link on the left from this site), or the easy2svcd one (www.easy2svcd.tmfweb.nl). Faster, better then do it all in one time.
Rgrds, Co. -
Actually it does. I prefer to use tooLame to encode the audio over TMPGenc, and CCEs audio encode sucks! Now how much faster I can't really say. One thing to keep in mind is what you want to do with the resulting MPV/MPA files. I like to have seperate files so I can play/edit them.
But this means more steps. If you just want to make a MPEG while you sleep/at work, then a few minutes won't really make a huge difference
How long does it take for you guys to re-encode a movie from avi (DivX) to VCD using the standard VideoCD template in TMPGenc?
For a 90 minute movie it takes me 100 minutes, using the standard VideoCD template in TMPGenc? Don't think that's to bad! -
That's 1.1x the movie runtime.
I have a Tbird 1.2Ghz w/ 512MB ram. I only do MPEG2 stuff these days thou. With CCE I get encode times around 1.1x the movie runtime, but with TMPGenc I get ~2.5x the movie runtime. Not sure what I'd get with MPEG1, but it would be faster
Do a search on this and you'll find lots of systems/setups vs. time.
I have no idea how much does this cost
By Artas1984 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 9th Jan 2012, 13:47 -
How I can reduce the time consumption?
By ramz in forum EditingReplies: 11Last Post: 7th Jun 2010, 10:42 -
I just had a really funny idea, but no idea how to do it, help =)
By NukeyDoo in forum Newbie / General discussionsReplies: 3Last Post: 30th Aug 2009, 05:47 -
Idea for freebie
By MilesAhead in forum SVCD2DVD & VOB2MPGReplies: 0Last Post: 29th Jun 2009, 23:58 -
Any idea what this cartridge is?
By zevious in forum Newbie / General discussionsReplies: 3Last Post: 9th Mar 2009, 13:33
