Should I be using the "Video CD (non-standard)" or the "System (VBR)" setting in TMPG for doing XVCD's. I have been doing XVCD's for a while now and have been using the non-standard setting. My problem is that sometimes when I encode the file size is way less than it is supposed be (like 600 instead of 800MB). I also crop my widescreen movies so I get the nice black bars and was wondering if this affects the size and how would I account for this in my bitrate calculation.
If anybody can help me with these questions or suggest other possible errors I would be very thankful. There is nothing worse than only putting 600MB on a disk that can hold 800MB's.
Originally Posted by scottrempel
XVCD stands for eXtendedVCD. XVCD has same features as VCD but it is possible to use higher bitrates and higher resolution to get higher video quality. XVCD is basicly everything that uses MPEG1 video, is not within the VCD standard and burnt in "VCD"-Mode. :P
Thanks for the reply, but I have done like 50 XVCD's and am very aware of the basics. My main concern is the low file sizes I am getting.
If somebody with some more knowledge had any ideas I would like to here from you.
Thanks in advance.
Best Setting for DVDFab
By aprillia99 in forum Newbie / General discussionsReplies: 3Last Post: 11th Sep 2010, 21:11 -
jerky tmpg
By devdev in forum Authoring (DVD)Replies: 6Last Post: 12th Aug 2010, 08:14 -
tmpg dvd author - pal ntsc setting?
By jin007 in forum Authoring (DVD)Replies: 4Last Post: 19th Aug 2008, 14:39 -
which setting should i use
By fruitpassion in forum Video ConversionReplies: 4Last Post: 23rd Aug 2007, 19:58 -
I want some suggestions for setting up a speaker system
By wan2no in forum AudioReplies: 4Last Post: 11th Aug 2007, 23:09
