I am using Virtualdubs Multisegment Capture (spill system) so that I can capture at 2 hardrives... The problem is that I can't figure out how to remove its' display which say's...
PICVideo
http://www.jpg.com
from the recorded video its' self.
any help would be great!!
thanks...
Your copy of the PICVideo MJPEG codec is an unregistered trial version. As the URL suggests, you can go here to register it for $18:
http://www.jpg.com/video/picreg.html
-Cart
http://www.geocities.com/lukesvideo/index.html
virtualdub capturing
By cesar110 in forum Capturing and VCRReplies: 1Last Post: 6th Aug 2011, 23:17 -
Bitrates, capturing with VirtualDub
By epicap in forum Capturing and VCRReplies: 4Last Post: 3rd Sep 2009, 10:49 -
Capturing using Virtualdub with Vista
By qwerty99 in forum Capturing and VCRReplies: 17Last Post: 27th Feb 2009, 20:59 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08 -
Virtualdub capturing resolution problem
By bloodshed in forum Newbie / General discussionsReplies: 3Last Post: 15th Jan 2008, 12:07
