  1. hi can any one tell me were i can get a freeware player to play my SVCD/VCDs i have the mpeg2 codec installed but i hate playin them in win media player my OS is win98 any help will be great
    nate
    Mar 2002
    United States of America
    PowerDVD is a great software player for playing SVCD/VCD.
    Mar 2002
    WinDVD is also a great choice. :P
    Mar 2002
    My OS is also a Windows 98. :P
  5. yer i,ve tryed both windvd and powerdvd but i could only get the demo i need sum thing free thanks for yur help
    nate
  6. nate_000, have you had a look in the tools section of this site?
    http://www.vcdhelp.com/tools#players
    I like the 'I-VCD Player', because it's really lightweight (I think it'll play whatever your WMP will - it picks up the same codecs for MPEG2 etc..). It's pretty simple, but good, if that's what you're looking for.
    There are quite a few other freeware players there to choose from though - I've not tried any of them, as I've got WinDVD and PowerDVD, but I'm sure you'll find something there that does what you're after.
    cheers,
    mcdruid.
    Mar 2002
    STHSVCD is a great player!!! :P
    Mar 2002
    Zoom Player is also. :P
