A few months ago, I made VCDs with low quality. I used up a lot of CD labels, color ink, and CD-Rs for them. But now, I can make VCDs with high quality but I ran out of color ink and CD labels. Is it worth it to go buy the supplies and redo all the VCDs so they're high quality? Your opinions are appreciated.
I think that's really up to you. I'm obsessive about quality, so I would probably redo them, if it was me.
Its definitely worth it to redo the movies if you know you can get much better quality. I dont think its worth it to make cd labels for VCDs at all, especially not a 2nd time. I just print up a front and back cover for the case and use a sharpie on the cd.
Need Opinions On Video
By budwzr in forum EditingReplies: 0Last Post: 23rd Aug 2011, 13:18 -
Audio Synching issue in Sony Vegas - What is the best way to solve my issue
By pandeyrajiv in forum EditingReplies: 2Last Post: 19th Dec 2010, 23:53 -
K-lite issue then mp4 issue
By Arch3type in forum Software PlayingReplies: 0Last Post: 15th Dec 2010, 11:57 -
Opinions Please
By OzarkBaby in forum Newbie / General discussionsReplies: 5Last Post: 17th Dec 2007, 16:11 -
Opinions welcomed
By mistik69 in forum Newbie / General discussionsReplies: 3Last Post: 7th Jun 2007, 21:50
