I have an avi which is too long to be encoded to SVCD in 1 part, so I split it into 2 parts in vdub. Audio was saved seperately as uncompressed wav, video was direct stream copy. The first half I ran through tmpgenc, it encoded fine, works great. The second half the audio is severely out of sync, like it plays 3-5 seconds before the video, and I have no idea why.
I mean, the audio begins at the same time as the video, and as the audio was perfectly in sync 1 frame before (the final frame of the first part) so how can it be so out of sync immediately in part 2? I tried cutting it again, resaving the audio, same problem. Why is this happening?
open the part2.avi file in virtualdub
go to audio/interleaving
there's a 'delay audio track' option
if you hear an event before you see it, the delay is positive
if you see it before you hear it, the delay is negative
the value is in 'ms'...
try it... you'll find out the perfect value to put there after 2 or 3 times -
But after cutting the audio and video aren't in 1 file. Original file is say movie.avi, then after cutting i have: movie-part1.avi, movie-part1.wav(that encodes a perfectly synced svcd) and movie-part2.avi and movie-part2.wav (and those encode an out of sync file)
so opening the avi in vdub doesnt have any audio anyway -
open the avi file in virtualdub
go to audio
select wav audio
open the wav file
and do as in the first reply -
Found out why I have the problem - after cutting, part 2 of the audio is 46:18 and the video is 46:29... How on earth does this happen? I cut them both on the exact same frame
And as for introducing an audio delay as you mentioned, I'd prefer not. There should be a way to fix it without doing that
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
Strange lip sync problem
By joe_kargan in forum Video Streaming DownloadingReplies: 1Last Post: 29th Apr 2011, 16:36 -
Strange audio sync problem with downloaded AVI
By embreeb in forum AudioReplies: 9Last Post: 9th Dec 2008, 08:30 -
Strange Audio Sync Problem
By innovyse in forum Video ConversionReplies: 2Last Post: 6th Dec 2007, 13:36 -
strange buzz in audio/subs out of sync
By mique in forum ffmpegX general discussionReplies: 1Last Post: 11th Oct 2007, 18:46
