Ive been trying for over a week now to convert a film i downloaded on the net to mpeg-2 for burning to a dvd-r ive cut the bad frames out with virtualdub so that tmpgenc wont crash during the encoding process, only problem i have is getting the end result to fit on a dvd-r, its either too big the quality is crap or the picture size isnt right, does anyone know of the best way to do it, ive tried the guides and they havent helped much.![]()
Results 1 to 1 of 1
How can you know if mencoder is using the results of the first pass...?
By divxmpegjpeg in forum Video ConversionReplies: 0Last Post: 13th Mar 2010, 19:12 -
Speed Test Results
By HmNtr in forum Off topicReplies: 0Last Post: 28th Dec 2008, 02:58 -
Mosaic Looking Results
By treed68 in forum DVD RippingReplies: 5Last Post: 27th Jul 2008, 05:20 -
What can I do for best picture results?
By BrokenOne in forum Newbie / General discussionsReplies: 3Last Post: 19th Apr 2008, 16:22 -
Help with Gspot Results
By Dawter in forum Newbie / General discussionsReplies: 1Last Post: 12th May 2007, 08:01
