I need to author a DVD with two separate audio tracks. One is the original english soundtrack and the second is the translation in local language.
I tried IFOEdit to mux the three streams into VOBs and create a DVD. The result is failing sync and erratic movement in the video.
Apart from scenarist (which I try to avoid as much as possible), anyone knows of other authoring tools that allow named language streams?
SaSi
Also, Pinnacle Impression DVDPro, Sonic/Daikin ReelDVD, Sonic DVDCreator, Apple DVDStudioPro.
There may be others.
Need a alternative to TMPGenc Authoring Works
By nitrocell in forum Video ConversionReplies: 1Last Post: 19th Dec 2011, 14:53 -
Authoring with more than 8 tracks of Audio
By RefresherEllie in forum Authoring (DVD)Replies: 9Last Post: 2nd Sep 2010, 23:33 -
Authoring DVD with four subtitle tracks and PCM audio?
By bizzybody in forum Authoring (DVD)Replies: 7Last Post: 28th Feb 2010, 22:17 -
authoring DVD with 2 audio tracks and soft subtitles
By Agent1266 in forum ffmpegX general discussionReplies: 6Last Post: 2nd Oct 2008, 15:34 -
Alternative AC3 cutting and joining tools
By 557953 in forum AudioReplies: 2Last Post: 21st Aug 2007, 11:11
