  1. I have been using virtuall Dub 1.4.10 to frameserve into tmpg because thats the only way I can create svcds that arent jerky. Now today I went to load the fake file that virtuall dub created and it wont load, it says that it unsupported. When I used it two days ago it worked fine and no changes have been made to any of the programs, so I cant figure out why this is happening. Ive looked through all of the fourums on this subject but I havent been able to find any thing that helps, any further ideas?
    Apr 2002
    The State of Frustration
    And your DirectShow priority set correctly?
    Hello.
  3. My Direct show setting is at 3 and everything else is at 0.
    Mar 2002
    chicago
    1.4.10? If you look through the forums, I believe you'll see that there are problems with frameserving from that version. go back to 1.4.9, or get the most current version and try again
    what are you askin' me for...
    I'm an idiot!
