Hey,
OK, i got my mjpeg codec and now i have another prob... It wont capture in the RGB 24 mode, it keeps dropping frames, any idea? so i tried yuy2 but that has lines in the video, only when people move they brake into line block things...
Matthew
Results 1 to 13 of 13
Ok, what resolution and fps are you trying to capture at? Do you have DMA enabled for your HD? Have you tried capture at say 352x240/15fps to see what happens? If you're still dropping frames at that low setting something is wrong with your setup/system.
Also turn off ALL background apps. Esp virus scanning software! Or auto-defragmentors. While it at it, defrag your HD too
have you looked at an IDE RAID card for your hard drives, it will let you stripe up to four drives makeing all four drives work together and increasing hard drive speed. It does matter how fast your CPU is or how much memory you have.
I have a 1.2 thunderbird I get no frame drops if I use the following settings, use Virtualdub for capturing and set at the following to see what happens
BTYUV AVI
29.97 frames
22050 16 bit stereo audio
with this setting I have captured up to 3.8 gigs with about 30 frame drops over the entire 3.8 gigs.
I usually get 1 frame drop out of every 1200 frames on the average. -
Mario yes CPU speed dose to help but you rigth IDE RAID is need to increasing the thougth put for a higher resolution.
Mdanner423 you know it my be eazy to just buy a Real-Time MPEG1,2 Hardware Encode like a Dazzle DVC II $300 or Hauppauge WinTV-PVR $250 for less money.
I have a pentium 3 800 and i can capture. With two drives striped on a RAID card.
BTYUV AVI
29.99
48000 16 bit stereo
720x480 frame size
I have captured about 4 gigs with no frames dropped.
I have the wintv pvr, i would love to be able to capture with it and EDIT the commercials... I have spent months trying to find i good mpeg joiner with no success!
Matthew -
Matthew
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Try to get a copy of "M2 Edit" its very good.
Convert .ts to other formats
By charmedangel in forum Video ConversionReplies: 13Last Post: 4th Mar 2012, 13:55 -
Video Formats
By andyf in forum Newbie / General discussionsReplies: 3Last Post: 13th Oct 2011, 04:10 -
hd formats
By devdev in forum EditingReplies: 6Last Post: 31st May 2010, 16:35 -
RMVB to other formats.
By POCHINI0 in forum MacReplies: 2Last Post: 13th Nov 2009, 20:32 -
Why so many formats?
By sequoia in forum Newbie / General discussionsReplies: 3Last Post: 30th Sep 2009, 16:39
