Hello can someone tells me why when i convert a avi to svcd or vcd with tmpg the movie ands as full screen movie if the movie before i convert him wide screen was.
thanks![]()
cuz u prolly have chosen the wrong aspect ratio: you need 4:3 or 16:9
Check in TMPG with SETTS -> ADVANCED -> SOURCE ASPECT RATIOWanne earn something a couple of dollars?
http://www.gold4email.com/signup.php?r=427
(^--no minimum pay-out!)
http://www.CashRoyal.com/cgi-bin/signup.cgi?r=sluarg1@hotmail.com -
Also, next to Video arrange Method under the Advanced Tab, set it to "Full screen (keep aspect ratio)".
Hope That Helps!!!
:P
Before you begin, make sure you hit CTRL+N to erase the settings before, AND then start again. Go in the Advanced Tab, and make sure you choose Full Screen (Keep Aspect Ratio). It should work.
Also you really should try searchin before you post quetions like these. -
you shouldn't say that.Originally Posted by DivXerouS
that's what we are here for. to help out the unfortunate when they need help. in the advanced bar, just set the aspect ratio to full screen (keep aspect ratio) like DivXerouS said.
I don't mean to be mean, but I posted a similar question and found the solution to it. I guess I shouldn't say that.
Problems converting AVI to vcd format using TMPGenc 2.5 Plus
By peterock in forum Video ConversionReplies: 2Last Post: 28th Dec 2008, 16:34 -
Converting AVI using TMPGenc = No Sound?
By CaptainChaos in forum Video ConversionReplies: 2Last Post: 16th Dec 2008, 17:12 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 15:17 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 12:41 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
