  1. i have pe version.
    well i have a peoject of 25 music vids i put to menus etc. well on the first menu ive made a play button and then i have a chapters button . id like to play the whole vid through seamlessly by pushing the play button. i link the first clip to the play button i then went into properties of that clip and manually set the next and end actions to the following clip (clip 2)
    i then linked all of my buttons to menus etc. and all is well
    upon playback though when i push the play button it will play the clip 1 only and keep going back to the menu when done!! yes i read the guide over and over!
    also any way to have background music to menus?
  2. The best way to do this is to encode all your clips into one clip and set chapter points where you want, and make a button or text link to each point of interest.
    adding audio to a menu, import your audio into the media palette, drag the audio file onto the menu or to the menu in the menu place holder
    Michael
    Learn to create DVDs the Ezway
    DVD Related Question Post them at
    www.EzDVDAdvisor.com
    DVD Developers Community
