I just installed the Leadtek tuner and I have encountered an issue. While watching TV on my monitor I get a black and white flickering line across the top of the screen. This happens no matter what size I make the viewing window. Anyone have a fix from experience?
Also, I would appreciate your insight on what software apps Leadtek users have found useful.
Thanks...
I think you have an underscan problem. If you use overscan you won't see the line anymore. The leadtek application doesn't have an overscan option, but you can use Dscaler. This is a free program and also gives a better picture quality. In Dscaler you also can view teletext. (the overscan option is in settings--> video adjustments)
Some other tips:
- You can get the free program called girder. This is an remote control application. Girder allows you to use the leadtek remote control for every application you want. You have to use the leadtek winfast plug-in
- If you want to capture you must get Virtualvcr. This free program allows you to capture in every resolution (up to 768*576).
Leadtek Winfast TV2000XP Expert problem with sound
By roc383 in forum Capturing and VCRReplies: 22Last Post: 1st Dec 2010, 12:32 -
Does the SpursEngine devices, IE Leadtek's WinFast PxVC1100 work good?
By TBoneit in forum Video ConversionReplies: 3Last Post: 15th Aug 2009, 17:50 -
Leadtek Winfast pvr2000 (retail)
By fulgur in forum Capturing and VCRReplies: 7Last Post: 4th Nov 2007, 10:05 -
Help: No sound at all with a Winfast TV2000 XP Deluxe
By Deathwish238 in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2007, 13:01 -
Leadtek Winfast TV2000 xp deluxe help
By Nuwanda in forum Capturing and VCRReplies: 0Last Post: 6th Jun 2007, 14:22
