All
The only way I have been able to "abridge" my mpeg2 files captured in ATI MMC was to go into TMPGEnc and go to -->MPEG TOOLS & pull the file in on the last tab. It lets me pull the file in, but now when I click the "edit" button I get the error above.
It worked fine before, and I didn't (knowingly) install any new software. Does anyone know how to fix this issue? I looked it up, and the only thing I found was to set the "directshow" priority to 1 or 2 in the options. I did that, and it still doesn't work.
I don't have mp2edit or womble or any of the other proggies that allow you to edit, this was my only outlet. . .
Please help!
Thanks!
-Anthony
"directshow" priority wont have any effect in there, can you load them into TMPGEnc as if you were going to convert them ? Perhaps convert them for a few minuets then test that in the Merge&Cut ?
Can not open any file in TMPGEnc 4
By Soixante in forum Video ConversionReplies: 4Last Post: 8th Sep 2010, 08:56 -
can't open file in TMPGEnc
By windranger in forum Newbie / General discussionsReplies: 12Last Post: 18th Feb 2009, 09:25 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
TMPGEnc 4.0 XPress Failed to open mts file
By jeremyotten in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 8th Mar 2008, 11:40 -
cannot open or unsupported file on tmpgenc
By Donna Stefani in forum Video ConversionReplies: 6Last Post: 15th Aug 2007, 20:31
