I'm trying to multiplex some video, audio, and some subtitles that I made with the "OGTCreator" that comes with I-Author. When I tell it to start, it looks like it's working, and then gives me a warning box that says "OGT Channel 1, first time over"
I searched the forum for anything related to this, and the only suggestion I saw was to take out some of the subtitles. I only have 4 subtitles, so I can't really see how they are taking up too much room. I would certainly appreciate any help with this matter.
Ben
By 4 Subtitles, I mean that I have four instances when words pop up... not 4 different tracks of subtitles (e.g. 4 different languages.)
Ben -
I bet someone on this site knows what's up... Thanks to anyone who offers any ideas.
Ben -
Well, I figured out the problem, and I'll explain it here so that someone else encountering the same thing can be helped. After overcoming this obstacle, I've run into another one.
First, the solution. I had encoded the mpeg at the maximum SVCD comliant bitrate, so when I tried to add subtitles, I-Author knew that there was no room to add more information and still keep it compliant. I reencoded the file at a slightly lower bitrate, tried again, and it succeeded in making the I-Author *.mps.
Now, the new problem. After creating the .cif disk image in I-Author, I tried to burn it with Easy CD Creator. It did about 90% of it, and then gave me an error that included the phrase "Data incomplete." A search of this forum showed me that Easy CD Creator 5 has this problem, but I have Easy CD Creator 4. Why does it give me this error? If I was to convert the .cif to bin/cue with CDMage, would I still have the subtitles that I muxed in with the video? I hope someone knows something more about this... I feel silly being the only one replying to my post
Ben -
If you use CDMage to convert the cif to bin and cue then you will still have the subs. All it is doing is converting the format of the image so that it can be burned by different programs, the actual data in the disk image doesnt change.
There is a very good chance Ez cd creator is messing up. You should always use CDMage to convert to bin and cue in my opinion. If there is in fact ANY problem whatsoever with your image then CDMage will tell you.
Anyone mirrored or saved OGT/CVD subbed test images?
By zinchronized in forum Newbie / General discussionsReplies: 5Last Post: 11th Aug 2010, 22:46 -
Looking for test SVCD images with CVD/OGT subs
By zinchronized in forum Authoring (VCD/SVCD)Replies: 0Last Post: 11th Aug 2010, 07:55 -
How to author a dvd from several xvid movies without sync problems
By rickywh in forum Authoring (DVD)Replies: 2Last Post: 8th Apr 2010, 14:02 -
TMPGenc DVD Author 3 Sound Problems
By wapdoggie in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2007, 16:00 -
Problems with TMPGEnc DVD Author 3 and multiple AVI files
By cadkins in forum Authoring (DVD)Replies: 6Last Post: 9th May 2007, 14:37
