i downloaded a divx movies and it has 2 parts each of them is 700mb and i join it with virtualdub so it came out with 1.4gb the thing i dont get is how come it has such big size file compare other movies i have in my hard drive
is anybody know how to shrink it and doesnt loase lots of quality thanks
It's probably a DVD-Rip as almost all DVD Rips are 700MB. :P
only way to lower the size is to lower the bitrate. By lowering the bitrate you WILL lose quality. How long is the movie? If it's a long movie, then trying to fit it onto 700mb may not be the best thing to do, since you'll have to drastically lower the bitrate.
PlaiBoi -
its minority report its about 2 hours 23 mins 11 secs................
heres the information for it:
AVI Information
Filename: Minority Report.avi
File Size: 1469310976 Bytes (1401.24 MB)
Streams (i.e. Video,Audio): 2
Video Stream
Compression: DIV3 - DivXMPEG-4 Low-Motion
Frames: 205997
Keyframes: 2390 (Every 86)
Framerate: 23.9760 fps
MicroSeconds Per Frame: 41708
Avg. Bitrate: 1166.60 kbit/s
Running Time: 8591.80 sec (2h 23m 12s)
Resolution: 640 x 272
Quality Level: 10000 (1-10000)
Color Depth: 24 Bits
Audio Stream
Wave Type: 8192 - Unknown Wave Format
Avg. Bitrate: 192.00 kbit/s
Sample Rate: 48000
Bit Depth: 0
Channels: 2 (i.e. Stereo)
Audio Delay: 0.000 Secs.
i guess the audio is ac3.............so if u guys have any ideas just reply it thanks)
If you lower the bitrate your going to have to re-encode which means a loss of quality.
You could download a DivX calculator to find the average bitrates that you want your files to be.
ok heres the other movie i have that is over 2 hours..... the bit rate is lower
but the quality seems good.....ans why is that??
here the information:
AVI Information
Filename: Enemy at the Gates.avi
File Size: 735340544 Bytes (701.28 MB)
Video Stream
Frames: 188572
Keyframes: 1548 (Every 121)
Avg. Bitrate: 607.25 kbit/s
Running Time: 7865.02 sec (2h 11m 5s)
Resolution: 560 x 240
Quality Level: -1 (1-10000)
Audio Stream
Wave Type: 85 - MP3 Audio Layer
Avg. Bitrate: 128.00 kbit/s
Sample Rate: 48000
Bit Depth: 0
shrink a vob file
By natty in forum Newbie / General discussionsReplies: 13Last Post: 5th Dec 2011, 13:06 -
How to shrink a large .M2TS file?
By neworldman in forum Blu-ray RippingReplies: 2Last Post: 12th Jun 2010, 08:16 -
shrink avi/divx in batch mode
By volam1 in forum EditingReplies: 1Last Post: 5th Jan 2010, 20:20 -
Shrink MKV file
By jjrdias in forum Newbie / General discussionsReplies: 2Last Post: 17th Jan 2009, 19:20 -
How can I shrink an mpeg2 file?
By JBredensteiner in forum Video ConversionReplies: 16Last Post: 3rd May 2008, 23:27
